So, I did this earlier…
Messy as hell which I didn’t expect… I tried the method of connecting a clear hose to the low pressure line and turned the wheel back and forth but the fluid didn’t come out how I thought it might or at all… A very slow dribble at best.
I connected my pipework to the low pressure like that goes from the top of the reservoir to the pump, on the reservoir side.
After deducing that nothing significant was happening… I decided to start the engine very briefly… Lots of fluid came out with considerable pressure and gave the whole engine bay a good coating… *insert swear word here *.
So, I had a rethink…
I reattached the line to the reservoir and detached the other end that’s connected to the pump… I’ve now got my hose adapter connected to the end of the low pressure return line (imagine it being between the pipe and the pump), the theory being that when I turned the engine over the previous time, the outlet at the top of the reservoir is where the fluid came out at high pressure, so now when I turn it over again I’ve got my hose connected to it and directed into a drain pan…
Next problem: can’t have the pump sucking air…
So, I filled a large container with 3 litres of clean fluid and then connected another length of hose to the metal hose adapter on the PAS pump itself with the other end going into my make shift reservoir full of clean new fluid, the idea being that the old stuff comes out of one end and is replaced with the new fluid being drawn in via the pump…
Then VERY quickly, started the engine, and gave it 4 full locks in either direction before the clean fluid ran dry (it moves through the system very quickly)…
Engine off, all pipework reinstated a sit should be and then a test drive with plenty of corners, including some lock to lock turns in a car park… Got back home, dip tested the reservoir and the fluid is crystal clear (or red).
No funny noises, steering is noticeably lighter and smoother, no leaks.
I’ll call that a success!
If anyone wants anymore specific information on this method get in touch
