Day 1.
Hours spent today: 9 hours
It took me all day, but I’ve removed everything from the front right corner.
It’s a steep learning curve. Other than changing shocks on a hatchback and doing little jobs like ARB links, this is the biggest suspension job I’ve taken on.
I knew the suspension strut needed to come out, so using my Haynes manual book of lies, I started with that, but then realised that it would be easier to crack all the bolts on everything so I knew where the problem areas were.
I got all the bolts cracked except the caster adjustment nut and bolt, which was seized solid.
I knew one of the castor bolts was seized because my alignment guy told me. He tried a bit of heat and an impact wrench at the time, but it was solid. Luckily the seized castor bolt position was pretty good, so we agreed to leave it.
Until now.
So, I removed everything else to help with access of the lower wishbone.
Using heat I got the castor adjustment nut off, but the bolt was seized solid. As a flexed the arm through its axis I could see a small gap appearing under the adjustment washer, so I knew it was the shaft of the bolt itself seized to the inner bush.
Lots of penetrating fluid and heat failed to budge it.
I resorted to cutting it off, and it took me literally hours. At the top I had to cut through the inner bush and the bolt. Thankfully once that was off I had a bit of wriggle room with a gap to get the saw blade directly on the lower part of the bolt.
I wish I’d bought a mains powered reciprocating saw rather than a cordless, It took several battery swaps to get both cuts done.
I’ve already bought 2 front castor adjustment bolt kits because I knew at least one was seized, and luckily so far it’s the only one I’ve needed to cut off.
I’m tempted to have a break from being on my hands and knees and spend the day tomorrow in the garage at the vice making a start on removing some of the bushes, but it’s forecast to be nice again so I guess I’d better get out there and remove the other side.
I’ll hopefully work more quickly tomorrow. It’s fresh in my mind what tools work best where, and I’ll be delighted if the other castor bolt isn’t seized. Today I was pausing to take pics at each stage in case I got confused about what goes where upon reassembly, but it’s quite straightforward and I won’t bother tomorrow. The arms are marked left and right, and the direction that the ball joint spindle points dictates which way round they go.
So, looking forward to a more straightforward day tomorrow, and hopefully I’ll get everything off the front left corner with minimal cutting.
Thanks for reading and any comments are welcome.
