Day 10
Hours spent today: 5
Rear suspension
Today started well, but then I ran into some problems and would appreciate some advice on moving forward.
The ABS sensors in both the rear hub carriers are stuck in there. After removing to 10mm retaining bolt I got a tiny bit of rotation by levering on the end of the egg shaped washer which the sensor is mounted to, but even after working it back and forth and using penetrating fluid, they’re stuck.
I decided to work around them, which is annoying. Any advice on safely removing these would be appreciated.
I slackened the suspension bolts in situ. All the ball joints came loose apart from the bottom one with the pinch bolt (I think it’s called rear toe control). The steel pinch bolt was stuck solid in the alloy hub carrier on both sides.
I decided to drill out the bolts, and I messed up
Using an angle grinder I carefully cut off the threaded end of the bolts, and then cut the bolt heads off.
I then made mistake number one.
I decided to also cut the bolt at the split in the pinch part of the hub carrier, to reduce the amount of drilling. As I started the cut I realized the rubber boot must be close underneath, but it was too late, I’d nicked it and grease oozed out
I’ve found the part number for a replacement boot: f151-28-4a3. I can’t find them in stock in the UK anywhere.
I have seen several places selling a rubber boot listed as “upper control arm / toe control”. Is the rubber boot on the front upper control arm the same size as the tie control boot in the rear?
I can’t get a front wheel off to check properly at the moment because the back of the car is up in the air.
Also, any advice on how to fit these and if any special tools are required would be appreciated.
I then made mistake number 2.
Using a centrepunch I marked the centre of the bolt (or so I thought) and drilled out the bolts, but I was about 1-2mm off centre on both bolts. I’m kicking myself
I think when marking the centre point with the punch I didn’t take into account the fact that the circle I was looking at was the edge to the thread on one side and the edge of the actual bolt shaft on the other side.
Or I just didn’t mark it very well
Anyway, there’s a bit of thread and bolt left in place and the ball joints are still solidly in there. The only remedy I can think of is to use a round file to remove the remains of the bolt, and then fit oversized bolts and nuts.
Please can anyone offer some guidance to help me out if this hole I’ve dug?
