- My model of MX-5 is: __2018 ND RF
- I’m based near: __SURREY
- I’m looking for technical help or recommendations on: __GEAR OIL
Hi all
Which gear oil should I use for changing in 5 year service
6 speed manual
Kevin
Hi all
6 speed manual
Kevin
Interested in reply’s myself
After consultations on here I used this Millers Oils Motorsport CRX 75w90 NT+ Fully Synthetic synth Gear Oil 5L | eBay
My observations are that the first few gear changes from cold are a little ‘sticky’. More so than the original oil. It ‘warms up’ within a mile and the change becomes slick. Once fully warm the change is faultless. (Note this gear box does not like to be ‘rushed’ even when hot and this oil does not change this).
I would recommend changing the differential oil as well, I used this Diff Oil, Genuine Mazda Long Life Hypoid SG1, 1 Ltr, Mk4 & RF – MX5 Parts
Don’t forget new sealing washers. (you could get away with reusing but buy in bulk and they are pence)
Plus, undo the filler first just to be on the safe side!!
I’d recommend Millers CRX LS 75w/90 NT+ for the differential.
Thanks gents, I am new to car servicing at this level… where is the diff?
Thanks again
Kevin
Rear axle is the diff.
