There is a diagnostic procedure for the hands free telephone unit in the USA 2011 manual (I don’t have the UK/European manual). It can’t hurt to try this.
- Turn the ignition switch to the ACC or ON position.
2. Turn the audio unit power to OFF.
3. While pressing the POWER/VOLUME switch, simultaneously press the PRESET switch 1 and the PRESET switch 6 for 3 s or more.
{Device code and error code is displayed}
NOTE:
If several DTCs are in the memory, they can be displayed using the SEEK/TRACK switch (up or down).
4. To stop the on-board diagnostic test mode, turn the ignition switch to the LOCK position.
There is a table of error codes and possible causes, pasted below as a list:
26: Er81
HF/TEL function does not operate.
CAN system
(See FOREWORD [MULTIPLEX COMMUNICATION SYSTEM].)
26: Er82
Sound from microphone not heard
Short to power supply in wiring harness between microphone (Input signal) and HF/TEL unit
(See FOREWORD [HANDS-FREE TELEPHONE (HF/TEL) SYSTEM].)
26: Er83
Short to GND/power supply in microphone power supply circuit
26: Er84
Call transmission and receiving is impossible
Any of the following is detected:
The microphone power supply circuit is not connected.
Open circuit in the microphone input circuit
Microphone input circuit short to body ground
26: Er85
Poor contact in the voice recognition/hands-free switch or HF/TEL unit connector
Voice recognition/hands-free switch malfunction
26: Er86
HF/TEL unit malfunction
Replace the HF/TEL unit.
(See HANDS-FREE TELEPHONE (HF/TEL) UNIT REMOVAL/INSTALLATION.)
To clear the codes:
2. While pressing the AUTO-M switch, simultaneously press the RPT/PRESET switch 4 for 2 s or more.
