Here sre the FACTS from theDepartment for Transport website, the red highlight is done by me
Fact sheet: Aftermarket HID headlamps
December 2006
In
the Department's view it is not legal to sell or use after market HID
lighting kits, for converting conventional Halogen headlamps to HID
Xenon. If a customer wants to convert his vehicle to Xenon HID he must
purchase completely new Xenon HID headlamps. The reason for this is
that the existing lens and reflector are designed around a Halogen
filament bulb, working to very precise tolerances. If one places a HID
"burner" (bulb) in the headlamp, the beam pattern will not be correct,
there will be glare in some places and not enough light in other places
within the beam pattern.
The following is the legal rationale:
The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK. Under
these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned
and therefore they are not permitted according to the strict letter of
the law.
However new vehicles have HID headlamps.
This is because they comply to European type approval Regulations. The
UK cannot refuse to register a vehicle with a European type approval.
These are to ECE Regulation 98 (for the HID headlamps which are tested
on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation
on the vehicle).
For the after market, a used
vehicle cannot obtain type approval because it is only applicable for
new vehicles. However we feel that saying “HID is banned in the after
market” would not be reasonable. Instead we should make analogies with
new vehicles. It would be reasonable to require HID in the after market
to meet the same safety standards as on new vehicles. The same level of
safety should apply.
Therefore a HID headlamp unit sold in the after market should:
be type approved to ECE Regulation 98 as a component.
when fitted to the vehicle should enable ECE Regulation 48 to be
complied with (although no government inspection will take place).
Comply with RVLR as far as “use” is concerned.
In practice this means:
1.
The headlamp unit (outer lens, reflector, bulb) shall be type approved
to ECE 98 and be “e-marked” to demonstrate this. That can only be done
by the headlamp supplier - Hella, Valeo etc. who must test the headlamp
in an independent laboratory.
2. Once fitted to the
vehicle it must have headlamp cleaning and self-levelling (which can be
for the headlamp or can be in the vehicle suspension - some expensive
estate cars have “self-levelling suspension” and that is adequate).
Also the dipped beam must stay on with the main beam.
The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In
summary it is not permitted to convert an existing halogen headlamp
unit for use with HID bulbs. The entire headlamp unit must be replaced
with one designed and approved for use with HID bulbs and it must be
installed in accordance with the rules stated above.
If
you require any further information regarding the regulations covered
by this fact sheet, please contact the DfT at the address below:
Transport Technology and Standards 6 Department for Transport Zone 2/04 Great Minster House 76 Marsham Street London SW1P 4DR
I hope that makes it clear enough, as I said earlier, people have fitted HID lights to the MX5 Mk1, but they/you do so at your own risk, it’s your licence that will get the points not mine[;)]
These High Intensity Discharge
(HID) headlamp kits are offered as an upgrade to standard H4 type
bulbs. They are E-mark Approved (E13) and should be fitted in
accordance with the manufacturer’s instructions and to the correct beam
alignment for your car. As with any aftermarket accessory it is the
responsibility of the purchaser to determine suitability of this
product for their use. Please check that this product conforms to any
regional regulations.
This product conforms to:
ISO 9001: 2000
ISO 14001: 2004
OHSAS 18001: 2001
HSPM QC 080000
E-mark (E13) 10R-02 9538
E13 is a Luxembourg type approval. Luxembourg approvals are done on a one time basis, whereas German (E1) are retested annually. A lot of E13 testing is carried out outside the EU, by approved testing agencies, such as in China. Guess which is the cheaper standard to pass. There are also allegations that some companies are misselling these kits; parts of the kits might indeed be type approved (and in the ad, there is no indication as to which EU directive is being fulfilled, it could be tractor trailer lighting for all I know), but the entire kit itself is not. The other numbers quoted are meaningless as far as product legality or safety goes; they are basically manufacturing standards.
There should be a test report available, relating to the ECE number Moss quotes (and Moss should have seen), which is similar in format to this:
Found these a while ago whilst ordering spares for my Jag. Not cheap but you do get a complete kit including new head light units. Should fit any car with 7" head lights.
