People of MX5 OC, I come to you with a confession.
Im crap at driving my car.
I have owned it for just over a year. I love the car, I really do. It’s a 2006 2.0l Sport (LSD/6 speed box). It’s great fun to drive, but I have to confess, that I find a lot of my gear changes, especially when I’m revving quite hard, to be a little jerky and uncomfortable.
Now firstly, Im aware how precise the clutch and gearbox is and that it’s never going to be the same lazy clutch of a normal everyday car. I spent three months thinking the gearbox was knackered, when it turns out that my seat wasn’t properly adjusted…by just one notch(doh). But even though this improved things, I still cant seem to get it quite right. Most of the time, changing gear is fine (apart from the well known issue of the 6 speed box being a bit notchy and stiff especially when cold). But I find upshifting in the lower gears when revving hard to be very jerky and Im sure it’s just me.
Here’s a for instance; Im accelerating hard along a sliproad. So im in 2nd gear and decide to rev quite hard. Becuase I’m accelerating I tend to push the clutch in, change gear and lift the clutch quite quickly. But I often find that this cause the car to ‘lurch’ slightly as if braking and then there’s a jerk as I re-engage the clutch in 3rd gear.
What am I doing wrong? I figured that Im being too heavy and quick on the clutch and doing it more slowly does seem to feel a lot better - but when Im pushing on, I feel like my gear changes should be as quick as possible. And if I lift the clutch too slowly, I can hear it slipping a bit too much as it engages, and I dont want to wear it unneccesarily. I just cant quite seem to nail it everytime. The same goes for switching from first - to second gear. I can never seem to do it smoothly. This morning, I tried pulling away hard from a roundabout and not changing to second until I was at about 4K RPM - the result was very jerky.
I understand that this car also has a lightened flywheel - could this acocunt for jerky changes sometimes? Is the engine not carrying enough momentum to make smooth shifting easy? Im quite confident that the gearbox and clutch is in good condition - the bite point is low and positive. Im sure this is more down to poor balancing of throttle and clutch.
So, in a nutshell - am I just a crap driver with no finesse, or is there a technique/method to smooth shifting that Im missing? Would really appreciate your view if you drive a 6-speed and any tips or pointers you might have.
