Mazda don't want to sell me an extended warranty...
They did send me a letter saying if I took one out by 9th November preferential pricing would apply, after that date a higher price level would be in force…
Thought it would be interesting to hear what they have to say at least.
Two times on hold today with wait times in excess of 5 minutes was enough, thought that was worth mentioning to the signatory of the letter.
The published email address of the Mazda Warranty Services Manager (Your message wasn’t delivered toĀ nnn@nnn.co.uk (deliberately obscured)Ā because the address couldn’t be found or is unable to receive email.) came back as undelivered, I have double checked that I typed it in as printed in the letter.
Sure it’s administered through a third party company (Allianz), it does come on Mazda branded paper though and offers a service in the Mazda name, not good at all…
I got the same letter, same end date too. Spoke to them on Friday and they were available, pleasant, knowledgeable and helpful.
Ā
Try again?
Ā
(still not decided on extending my warranty though)
I’ve received that letter too but I’ve only tried to get quotes online.Ā  They give 3 levels, ā€œcompleteā€, ā€œeliteā€ and ā€œessentialā€, and ā€œessentialā€ seemed good enough for what I want but every time I’ve tried the only quote they will give me is for ā€œcompleteā€ (only level applicable for my car!)at Ā£423.18 per year!Ā  So I think it’s all a bit of a ā€œcome-onā€ and probably won’t pursue it any further.
Speak to them; the online quote is nonsense.
Ian - Surprised you asked Mazda, whose warranty is normally carried by the dealer who sells the car, Mazda themselves say - ā€œSee the Dealer for warranty issuesā€. They will only respond under exceptional circumstances and then only to cover their back.This I know well, from the Mk2.5 clutch problems. I had to approach U.K. directors directly before they became involved.- This, I still think put a redline under my name, as inquiries afterwards remained unanswered. It did however do the job intended. as eventually we did get a good clutch.
Having said that (old news) your post can only be described as confusing, as what you reproduce from a letter from Mazda does not match what you said in the header?
Quote - ā€œThey did send me a letter saying if I took one out by 9th November preferential pricing would apply, after that date a higher price level would be in forceā€¦ā€ - Unquote.
Or are you assuming a non reply means ā€œNOā€ ? Send 'em the cash!
Maybe, though I was pretty annoyed after two periods of holding without pick-up, if that’s how they handle new business…
I had that too which didn’t endear me to the process.
Gerry, it’s an extended warranty after the 3 year dealer managed one has finished, backed by an insurance company.
My header is correct since if they wanted to then their systems would be designed to answer in good time or arrange quickly to call you back and the published email address would work, sloppy.
And the purpose of a Mazda warranty isĀ Ā
I find it a big relief when the 3 year manufacturer warranty isĀ  over so I can take my car to a proper garage.
Must admit I’m thinking along those lines too!
Ian - I see you point. Extended warranties are widely available, both on the box, through the AA and the RAC etc. Any which way, far too expensive for the cover you get, and probably loads of small print so they are well protected. In this instance, it appears Mazda are offering extended warranties on behalf of some Insurance Company, which usually means taking commission from any deal. Save the premium each year you own the car, and that will often pay for any additional repairs you may need. (Mk 4 gear boxes excluded!)
The Gearbox is the only reason I’m considering it.
My car is 3yr old and no one has contacted me about extended warrantyĀ
That would be the only reason for me too and the way I read it the ā€œessentialā€ warranty should be enough for that.  Please keep us posted on any developments Ian.   Many thanks.
Rodders - you are joking of course! You’ve probably got a red line under your name, as I felt I did.
Surely its car’s not car, the first MK4 you raced tried to kill you during the Race of Remembrance in 2015, any very nearly succeeded on day two of racing, it was a write off.
The only letter you are likely to get from Mazda Paul, is the same ā€˜gagging letter’ sent by Mazda’s barristers to Jon Halliwell this time last year after he complained about his gearbox failing in his race car after only a few hours ! Then to add insult to injury they ran a tv commercial ’ now is a good day to take your MX5 on track’  shortly afterwards.
Jon has been racing MX5’s since 2004 and instigated the MAX5 Racing Series https://en.wikipedia.org/wiki/MaX5_Racing_Championship
Got through this morning relatively painlessly, coverage options in the £260 - 290 range which would go up by £150 if post the 9th Nov cut off date.
Ā
Extended warranties aren’t worth the paper they’re printed on. They always have so many exclusions and caveats that it’s almost impossible to make a claim for anything worthwhile.
Apart from the water pump replacement I got on my 4 year old car (not an MX-5) earlier this year obvs
