MeisterR Sportives - Advice before I buy
  1. My model of MX-5 is: NA
  2. I’m based near: Chesterfield
  3. I’m looking for technical help or recommendations on: Coilover Recommendations
Hi all, it’s me again.
I’m buying coilovers for my 5. For months I’ve been told MeisterR Sportives are brilliant for enjoyment on the road whilst still being comfortable enough.
I am 2 weeks away from buying and all the reviews I’ve read on here are now in direct contradiction to what people are saying to me regarding the quality of Sportives specifically, instead recommending alternatives that are nearly double the price.
I understand that the more expensive you get, the better. But I really am not trying to break bank here and £590 seems enough as it is.
I’ve asked all over and I either get people arguing amongst themselves over who has the biggest … or I get the nick taken out of me for asking in the first place.
So, MeisterR Sportives, for a car that I drive for fun, and will rarely see track action.
Yay or nay?
Cheers, :upside_down_face:
if you are replacing the suspension because its shot well yes you should…
from these I’d go BC racing
https://bofiracing.co.uk/running-gear/suspension/coilovers/model-mk1/?orderby=price-desc&paged=1
My experience on Sportiv+ on my NB.
First up double check that the units definitely have height adjustment.
The versions I bought don’t have height adjustment (no third collar) so my car rides too stiff at the rear to keep it’s ar$3 up. I’ve no complaints with the fronts at all. The car handles well and feels good at the steering.
The coating on the springs didn’t last very long.
You gets what you pays for at this price point.
Mine have been on for probably 4 years, 15k miles and other than the height adjustment issue they’ve been ok.
Hope this helps.
If you spend another £3/400 you will get adjustable damping. If you know what to do with that then it’s good. If you don’t it’s a waste of money. If there are more subtle differences included in the price I’m sure someone will put me right!
I recently bought want you are after for a steal but, because of the shite weather I haven’t fitted them so can’t advise on whether they are even worth the bother over standard stuff.
I only bought mine because they were a bargain. The original suspension is actually a coilover but with a larger diameter spring. Hence I am very wary about all the chat about how they are better but still with the same sort of ride comfort.
I recently fitted lowering springs to my standard dampers and with a reasonable tool kit changing your suspension is pretty straightforward.
My MK2.5 came with Meister Sportives; fitted by the previous owner. I haven’t driven one with the stock suspension in decent condition, so don’t really have much to compare it to, however:
‘As received’ the ride height was about 315mm (wheel arch to wheel centre) front and rear. I THINK this was the default height for the Sportives. This made it feel ****** awful on bumpy roads as the rear suspension, especially, was riding on the bump stops. Lifting the rear by 15mm to 330mm made it feel a lot better, but the front tyre was still hitting the inside of the arch on hard compression (fairly worn Rainsport 195/50 15 on stock wheels). Raising the front to ~320mm pretty much solved that, but made the car go dangerously light on the front at speed (tested in Mexico, Officer :wink: ). To counteract that, I raised the rear up another 5, or so mm to ~335mm which killed that feeling, and it now feels quite good (for ‘spirited’ road driving - I also intend to fit a front spitter / air dam at some point). So I ended up at 320mm in the front and ~335mm at the back (~12.6" front / 13.2" back) which is pretty much as high as the Meister Sportives will go on my car.
I think the suspension ratios for the NA are slightly different - especially at the rear which may make a difference. They’re actually OK, but if I was buying from scratch, I’d try and stretch to something with adjustable damping. (Just because…)
Problem is ask 10 people and you will get 10 different answers.
It maybe worth you having a chat with one of the respected companies that set the geometry up on these cars to see what they suggest really.
Ive read mixed reports on the sportives but they seem to be mostly positive, the chap that used to sell them was active on a lot of forums but ive not seen him for a while.
Gaz were another that seemed well respected but are forgotton about.
I ended up getting GAZ. Cheers for the input though fellas :saluting_face:
Thanks for the update.
It may help others if you have time to add your thoughts on the Gaz set up once you’ve had a chance to drive your car.
I’m interested to hear your experience
Edit* Just spotted your thread on the bouncing issues. Hope you get it sorted.
I can wholly recommend the GAZ shocks.
When I (eventually) got my head around the bounciness, the car now glides over bumps as though I’m in a £50K Merc.
Still fell it on rough roads, but I don’t think any car can handle that terrain well.
Thanks for all the pointers. Sorry for not being mega-active on my threads, the forum barely works on my iPhone for some reason.
Thanks for the update. Glad the suspension is working for you.
Our of interest, how did you overcome the bounciness?
Have a look here GAZ Gold Professional - Bouncy? - Technical Area / Steering & Suspension - MX-5 Owners Club Forum
Chap above posted what I was about to send haha
Just fitted the full Meister cheapo to my NC1. They are harsher than my original shocks with lowering springs but the fresh damping is welcome: you can feel the difference.-. I’ve left off the yellow spot rear ABR and the car feels fine, more lively even.
You are using mobile view and not desktop aren’t you? Option to change is at the bottom of the menu with the 3 lines.
Well ■■■■■■ me. That actually worked :joy:
If you’re going on comfy country road driving of a Sunday then crack on with the Sportives, if it’s more of a spirited drive you’ll be undertaking go for the Sport-Z’s yes they are more expensive but someone is flogging a set nearly new on marketplace for about a £100 more than the new Sportives :person_shrugging:t3:
