Newcomer here. Please be gentle.
I’ve had my Mk2.5 for about six months. It’s a bit scruffy but generally works well, apart from one thing. Occasionally the engine cuts out altogether at higher revs, and recovers only when the revs drop to 4,000rpm. The point of cut-out varies but the point of recovery is always the same.
So, for example, if I am accelerating in 3rd gear, it may let me get to 6,000+rpm or it may suddenly die at, typically, 4,500. No power from the engine whatsoever. If I just let the speed decay, power comes back fully the instant the engine speed drops to 4,000rpm, and it will almost always then allow me to rev it as fast as I want. Alternatively, just declutching and throttling back for an instant is also enough to restore power.
It generally needs to be quite a lot above 4,000rpm, but not always. Cruising on the motorway at just a whisker over 4,000rpm the other day the engine would cut out, I’d slow down very slightly, revs would drop to 4,000rpm, power would com back and I’d accelerate slightly again. Happened maybe every 20 minutes or so.
Some days it doesn’t happen at all. Some days it happens frequently. It’s worse when the engine is cold and worse, I think, when the road is wet.
Has anyone any bright ideas? I’ve done a bit of Googling and have acquired spare coil packs (don’t think it’s that, because I lose all power, not half), cam position sensor and crank position sensor) and would welcome advice on the best order in which to try replacing them … if replacing them is worth doing at all.
Losing all power, even just for a few seconds, as you’re snicking past someone on an A-road is … character forming. I’d like to get it sorted.
