Mk3.5 NC Bose removal/overhaul due to - CHECK CD message
I’ve had the dreaded ‘CHECK CD’ on the Bose 6CD stereo. It was like that when I bought the car and I wasn’t too worried about it as I knew I could integrate the iphone and ipod to give all the music required. Figured I’d probably get a newer unit anyway at some future point.
This morning I thought I’d take a closer look and do some dismantling. Don’t know why …think my inquisitive side took over!! I had tried a few of the suggested remedies found online, holding down buttons, thumping the dash above the unit, disconnecting the battery even. All to no avail. The unit would not even take a cleaning disc without saying CHECK CD.
There is quite a lot to be found online for the Mk3 radio removal but not too much for the 3.5. Things are a little different from the gear shift to the heated seat fascia section and the side cheeks. The side cheeks on the mk3.5 you cannot get out without removing the section between the seats.
This youtube video gave me quite a few valuable insights.
https://www.youtube.com/watch?v=fOddbUjympA
My car is the automatic and I found there are 2 plugs to disconnect on the underside of the centre section. One is easy the smaller white one is a little more tricky. Then it comes out as in the video. Then you can remove 2 more screws and slide forward the side cheeks to remove.
Having got as far as the radio removal itself, this next video shows how to get the radio out. Make sure you put some protective tape around the unit, remove the gearknob and wrap a protective cloth around the gear shift rod. You don’t want to damage the radio facia getting it out. Basically there is one screw each side (covered by those side cheeks) and the PITA 10mm security bolt that you’ll see in the video. Then you prise the radio out with your fingers and thumbs as shown in the video. Gentle but firm pressure and you’ll feel it start to ease forward. The cabling behind gives a fair degree of resistance to your pulling of the unit.
https://www.youtube.com/watch?v=2RaFYIvFm1s
The loom is quite a tight fit and you’ll need to disconnect the plug to the a/c unit and 2 plugs and the aerial on the radio part. They are bloody hard work. All I can say is persevere and stay calm.
This is how it looks with the centre section, side cheeks and radio removed
A closer shot of where the radio came out showing the connectors
You can see the cabling I did a couple of weeks back to integrate the ipod and iphone using the aux socket.
Here’s a close up
Next it was take the radio to the workbench and have a good look.
I wondered if there was a CD stuck or part of a label from a homemade CD or a dirty lens …it was puzzling me.
This is the unit from the back. In case anyone needs detail of the connectors.
There are 4 pink coloured screws to remove and then the unit can be removed from the front section. Remove the one small screw from the front top area of the lid section and the lid can be prised gently upwards and off to reveal the mechanism interior. Be very careful going in here! I gave the interior a gentle blow out with a low pressure airline. But there was nothing really of any note loose inside. There was no label and no CD stuck in the wrong place! Then I carefully cleaned the laser with a cotton bud and ispropanol. The Cd spindle and laser are on the left hand side (looking from the front of the unit). You’ll need to very gently lift this to get to the laser head. I could also see a slight deflection on the thin silver plate at the bottom, under which is a large ring gear. Whilst there i figured I’d straighten that plate as best as I could as it could have been pressing down onto the ring gear. Sorry, I should have taken pics of all this but I became totally engrossed in what I was doing and ensuring i put it back together correctly
Then I put the whole lot back together and refitted into the dash. This part is bloody awkward … to both get the connectors back on and push the looms aside to get the unit back in. Much cursing and grunting later and it was all back in place. There is pleasing sound of the unit going through its start up motions as the connectors are attached. But what will follow?
Cripes it works!!!
I honestly don’t know what part gave the cure … all I can say is that now THE CD WORKS!!!
It has 6 CD’s loaded with Originals, burnt copies and an MP3 cd holding 64 tracks…and they are all working perfectly…thus far anyway!
I hope that is helpful to some of you with Mk3.5’s that have had the CHECK CD issue. It may just be worth a try for you too!
Nice one
Well done that man! There’s always something very rewarding when you have a go yourself and fix something! Looks like a very " faffy" job but perservance has won out!
Pleased to say, after a couple of days…all still working perfectly
I suspect it was cleaning the lens with isopropanol that did the trick. Used to do that with CD drives for desktops and the old tape backup machines when I used to repair them. Well done though
Really good, detailed write-up. Thank you.
Thank you for the kind words.
I’ve got a lot of info from this site over the years so figured I’d better try and give some back when I can.
10 days on and the CD player is still performing faultlessly
Must have changed disc about 8 or 9 times and all working perfectly.
If anyone has the dreaded ‘CHECK CD’ message this may be the answer.
I’m thinking this probably was a dirty laser lens.  Just odd that it would not even run a lens cleaning disc prior to the strip out and clean.
Just a heads up.
Over a year on and it’s all still working perfectly. Discs changed many times.
Unfortunately the photos of the strip down are no longer visible.
They might show if you follow this excellent link.
https://www.mx5oc.co.uk/forum/yaf_postst106595_Photobucket.aspx
Absolutely.
I have done this and every picture is there when I view it.
hi all
where do you put 6 cd’s… is it in the boot or through the unit ?
It’s through the unit, it is worth remembering that there is also a single disc unit fitted to some models.
Richard.
Is there a button marked ‘Load’ on the stereo unit fascia? Above there will be a logo with 6CD on it. You can see it clearly in one of my photos at the beginning of this thread. It was on the 4th photo.
If you have not then it is single CD at a time.
Good Morning.
I have just bought a Pioneer Apple play stereo and reading my Haynes Manuel it said about having to remove Air Con pipes!! I take it that you did not have to remove any A/C pipes during the removal of the stereo? As you mentioned in the original post I have been struggling to find instructions for the MK3.5 as mine is 2011 so thank you very much for this post, it has settled my nerves​:+1:t2::blush:
No, I did not have to touch any A/C pipes at all.
Thanks for resurrecting this post. i see the photos have vanished. I’ll have a look and see if I still have them on my PC at home. If I can suss how to I’ll reload the photos. Can be irritating when a post is not complete.
Found them!! These are the photos that went with the original post. I can’t edit them back in but hopefully this may help.
Thanks for the info.
Just started doing mine today. Have you or any other members used this?
I cannot seem to get any sound through my speakers and for the life of me I can’t figure out where the lead with the brown connectors go!!!
Someone please help. I used to be good at this sort of thing back in the early oo’s but I am totally lost.
Thanks in advance :+1:t2:
