- My model of MX-5 is: 1999 Sport Mk2 NB
- I’m based near: Cambridge
- I’m looking for technical help or recommendations on: Central Locking
Hi
I’ve just entered the MX-5 world with a purchase of a 1999 Mk2 Sport (the blue one!). I’ve been eyeing up an MX-5 for some time and finally went for it when this particular vehicle came up… couldn’t resist.
Anyway, while i wait for it to go in for full service and check over, I’ve had been doing the odd bit of checking it over where i can and making sure its as original as it possibly can be (i want to keep it that way if possible). From what i can see, including the original sales blurb, it should have central locking.
The car has come to me with 2 Mazda keys which i believe to be original. I also understand this model came with factory fitted with an immobiliser. Both keys unluck and start the car. However, no central locking appears to work and there was no remote fob supplied. The keys just lock/unlock the door they are used in.
Believing the car had central locking, I just bought a fob and went through the magic pairing procedure… several times. The car never responded by flicking the locks itself. In fact, i have never seen the car flick the locks itself. All that the car does is to give 3 beeps of what i believe to be the immobiliser (which to be fair is probably just because it thinks I’ve opened the drivers door and left the keys in the ignition).
So, my next thought was to check fuses and also (according to other posts) see if there is a locking control unit behind the glove box. Well, behind the glove box, there appears to be an aircon unit!! I was not expecting to see that. Similarly, I’ve yet to locate the fuse box …. is it under the steering column in an almost impossible place to find?
What I’d really like to know is, did this model actually come with Central Locking? The blurb says it did. Can anyone else with this model tell me if theirs did as standard? If it did, and to confirm if mine has too, is the controller still behind the glove box.. behind the AC? How can i spot it if its there??!! And the fuse box is worth a check (if i can find it!)?
I’d be really grateful to anyway who can help a newbie learn about this particular model ![]()
Cheers
Mike
