The Oval tie-down hole plugging gave me a small improvement when I took it round the M25 for skiing at Hemel Snowdome, but it isn’t the final solution, other sound pipes are available.
Ride height looks spot on for my preferences; standard 25AE suspension but with 215/45 tyres filling the wheel arches symmetrically centred and not looking slammed or 4x4. Alas it’s still not properly cleaned after dusty Compton Verney.
Today I did some minor fettling to improve the road-surface noise reduction; depending on type of surface it varies from totally inaudible to loud enough to require turning up the hifi. Most of it is now coming through the drains and from the shock absorber top mounts.
Curiously this was not the case with the Niseko; the underneath ends of these drains feel different with the lower flap valve a bit further inboard, and of course these shocks are the yellow jobs.
Fish-pond filter holey foam is now added to each drain outlet.
Some more Silentcoat deadening added, now around the conical metal of each top mount and on a couple more nearby flat body bits that might be ting-tinging a bit like the sounds we were hearing. Also some more of the absorber went on parts of the bulkhead and adjacent liner, not much room in there. But on a quick local loop these few odd bits seemed to have helped. No motorway test yet though.
While the boot liners were off I topped up the Dinitrol above the wheel arches. The long wand is only just long enough to reach if one uses a hole hidden behind the jack for driver’s side and the cut-out for the fuel filler for passenger side. Ideally it needs to have another 30cms.
The last bit done today is repairing the handbrake gaiter, otherwise immaculate it seems to have gained a stab wound or tear. The inside is seen here, edges already held in place by some gaffer tape on the outside.
I’ve applied a denim patch inside secured with trusty old Copydex. I’ll leave it to cure overnight before removing the gaffer tape and dressing the slit on the outside with some Vinyl-weld and a toothpick-brush.
Edit.
Gaffer tape removed to show the remaining scar
and my Vinyl-weld had gone orf so some black acrylic paint is just as good for something that will be hidden in a dark fold.
