- My model of MX-5 is: 1993 NA 1.6
- I’m based near: North West
- I’m looking for technical help or recommendations on: Electrical diagnosis & troubleshooting
Hello All,
I’m hoping someone more knowledgable and experienced than me might potentially be able to help out or suggest what to do next, as I’m at a bit of a cross roads with my 1993 Eunos at the moment.
For context, this has been a project car for the past year and a half (Thread detailing that on the forum here: https://forum.mx5oc.co.uk/t/my-1993-eunos-me-a-tale-of-foolishness-perseverance-dedication/144252). I had the car laid up over winter after getting it back from the bodyshop, and I noticed when I took it out earlier in March that it had a strange idle issue that would cause it to stall if I didn’t hold it manually with the throttle. After holding it for 20-30 seconds, it would eventually settle (Albeit at a lower than expected idle still, normally about 900 RPM even at cold).
When I took it out for a drive in March, after about 30 minutes and a short stretch doing 70 on a motorway, the fault developed even further to the point where the car would not maintain a base idle at all when stationery or changing into neutral whilst coming to a stop or slowing down.
To cut a long story short, I decided to cut my losses, get the car back and try to sort it out from home. My suspicions based on the symptoms were either the ISC Valve or air valve that sits on the side of the intake manifold. I did a resistance check on the ISC which came back as 11.3 which was just within spec, however when plugging/unplugging the ISC with power on I couldn’t hear the valve open and close, so I came to the conclusion it must have seized up, and so I ordered a used unit off ebay with the intention of swapping it out one evening and seeing where that got me.
In the interim I also ordered the diagnostic LED from Autolink thinking I could use that to double check my suspicions and see what the ECU was outputting, and whether or not it would confirm that it was the ISC or air valve.
Well I had a go at that earlier today, with the intention of swapping out the ISC after, but unfortunately what had happened is that I started up the car as usual, got it to idle and then plugged in the diagnostic cable. First I plugged in the shorting cable into GND & TEN, then the positive terminal of the LED into B+ and as I tried to push the negative terminal into FEN I could see a few sparks and then some smoke came out of the diagnositcs box, with the engine cutting out.
I immediately unplugged the cable (It was quite warm, so no doubt I managed to short something out), and attempted to re-start the engine but unfortunately it now doesn’t start up at all. It does crank and turn over, and I can tell the starter motor is definitely working, but I’m not getting anything else at all, so presumably no spark.
I just wondered if anyone here might be able to suggest what I can do next ? I don’t know whether it might be something as simple as a fuse (Fingers crossed) or whether I’ve completely fried the ECU. Does anyone know how I could diagnose this further, or maybe what fuses I could try swapping out to see if I can get the engine to start at least ?
Any advice at all would be appreciated !
