I’m looking for Technical help or recommendations on: airbag error codes…
I have a 2009 Sportech Roadster that has started to blink 4 slow and 2 fast airbag error lights on the dash.
Does anyone know what part of the airbag system this points to please?
I have done the easy stuff like battery out for 10 mins, and checking all the wiring under the seats and also checked for error code number on a scanner (none shown) - but have not managed to clear the fault.
Before I take it to a main dealer for some open wallet surgery I wonder if anyone here knows the answer.
Will get a mechanic to clear the codes, if I still have a problem then a £20 recon crash sensor at the front (after the nose has been removed) should fix it!
Robbie, I have had an mechanic put the computer on the car to see what the error code is and found the following errors, does this look like a new front crash sensor is needed to you?
B104D - Front Crash Sensor Cross Link to Another Sensor, and
B2856 - Airbag ECU Version Conflict with Front Crash Sensor Mount.
No other codes.
Any info before I pull the front of the car off would be appreciated.
Thanks.
R.
No other codes.
Thanks.
R.
