Hello all, new member from alloa, been lurking for a while and finally thought id make a post
Got a MK1 1.8 import in su classic red in decent condition, had it for a long time now but around 5 years ago I got a bit of work done to it and the engine died, so a mate swapped the engine and after that it never started and went into my mum’s garage and lived there untouched since
So I recently bought a house and built a garage and now I can play with it a such as possible
So in the past 4 odd weeks of having it back I’ve gotten the engine running - timing was 180 degrees out and the cam angle sensor was just jammed in with the alignment bolt
Welded the rear sill, the inner sill was totally solid which was ideal, the car had been resprayed before I got it so it’s a shame there was a £2 sized hole in the outer sill
Fitted a skidnation coolant reroute, fitted switchback led sidelights/indicstors, a new window regulator and sorted the rev9 door bushes so you don’t have to shoulder barge the doors to get out
I have a full g19 turbo kit with ev14s and an aem wideband sitting there as it has done now for about a year, I got one of the very last kits before they sold the rights to Motorsport electronic
Once I’ve finalised that the skidnation reroute isn’t pissing fluid and the sill finished I’ll get the me221 in and run it na on the basemap and see if I can get the wideband in and working and an oil pressure/temp guage from bofi before boost and itl be some jobs ticked off the to do list before it all begins
I had lost the v5 so waiting on a new one coming back, once there’s some stonechip on the sills and the v5s back itl almost mot worthy!
So plan is run it around before winter, prove the engine can take a pounding and then do boost over winter
I also very into my renaults and have a very decently track/road clio 182 with many carbon parts, fancy inlets and cams, polybushed everything blahblahblah
And an 8 month old husky pup called nook
tl;Dr - old 1.8 import revived for boost - is red
