So… 2010 NC.
All of a sudden, the central locking on both doors doesn’t work at all.
- The key fob is powered and the car receives its signal. If you lock both doors manually, you can switch on the alarm (flashing side lights). I can also pop the boot via the fob… so it’s not the fob.
- It’s not the 20 amp fuse to the central locking/boot lid. Replaced, and the boot lid pops anyway.
Here’s the big problem. Whilst I can unlock the driver side with the key and I can use the internal drive side door lock switch to lock and unlock that side, the passenger side’s door lock switch does not unlock the door.
The cables running from the passenger side internal door release and lock switch are connected to the actuator and lock, and seem to be doing what they are suppose to do, except that the lock doesn’t disengage.
So since the passenger door is locked, and keeping itself locked, I cannot open the door.
Even if I remove the door cards enough to access the actuator, there’s nothing I can do to release it and as far as I’m aware, I can’t remove it without getting at the three screws with the door open.
I’m not even sure it’s an actuator problem though, that a lot of people get. If it was, the driver side should still respond to key fob signals?
Could this be an electrical issue? Could the control module for the central locking (wherever that is on an NC, I can’t seem to find any information on the location of it), have malfunctioned and dead locked the doors? The driver side key may well of overridden the dead lock on that side, but perhaps, even with the internal lock switch functional, the passenger side lock just stays locked? Does this sound reasonable?
Would it be possible to give 12v into one of the pins to the actuators to get them going?
I don’t want to give up on this and hand the car to the Mazda dealer near me, as I’m going to get fleeced!
