Hi, I’ve got a 2001 1.6 NB MX-5 and I’m having some overheating issues. I bought the car to learn to do some more complex mechanics as I enjoy working on cars. I’m regretting it already!
I’ve got an overheating issue which I’m struggling with, it comes in two parts. The car has an aftermarket digital temp gauge and japspeed radiator.
Part 1 - Initially the car would sit and idle fine with the temperature at around 80, but after 10-20 minutes driving it it would shoot up to 100+, so I haven’t driven it far. It would overheat every time I tried driving, the temperature would be fine for a while but then start rising quickly despite not working the engine hard. It also intermittently lost coolant. There was no milky residue in the oil or white smoke from the exhaust.
I suspected a coolant leak, so used UV tracer dye but there’s been no sign of leaks and it didn’t lose coolant. I thought maybe the leak only happened at high pressure when the engine got properly hot, so I let it get up over 90 degrees but still no sign of any leaks and it overheated again. I know the coolant is flowing as the top hose gets hot.
I then thought maybe there could be some blockages so I’ve been flushing the coolant using STP coolant flush. In the process of flushing the coolant I took it on a gentle test drive to let it get hot, but the temperature still rose up to 100 at which point I cut the drive short, got home and found the header tank nearly empty again but no signs of a leak, no white smoke, no milky oil residue.
Part 2 - On repeating the flush for a second time, there is now lots of white smoke from the exhaust which doesn’t clear up, and it overheated again. I suspect a head gasket but there’s a chance letting it overheat has damaged the head or block. Either way I think it’s head-off time, but this may not be the real cause of the overheating.
So to my questions:
What are the chances that a head gasket was the problem all along despite no white smoke initially?
If the gasket is a new symptom of the underlying problem, does anyone have any ideas what that problem could be?
What should the next steps be in finding the cause of the overheating?
Thanks in advance
