My MX5 is looking rough and I maybe have 2 years left in it before the issues outprice the value of the car. In the mean time, I want it to temporarily look good for those remaining 2 years however.
For the arch bubbling, I plan to do it as well as I can without welding (as I can’t weld) so the usual sanding to bare metal, remove rust, treat, filler and paint.
The issue I have however is the engine bay. There’s just bits and pieces in really fiddly places I can’t realistically do as thorough job on while the engine is in the car. I was wondering therefore how viable a short-term bodge may be therefore and if anyone had any experience with it. In short, a quick wire brush to remove the loose debris, a liberal helping of Kurust rust converter and then a black anti-rust primer.
I know the rust will end up coming back, but should the above give a decent showing for it’s last couple of years?
My model of MX-5 is: __
I’m based near: __
I’m looking for technical help or recommendations on: __
You don’t say which model of MX5 you have. All MX5s rust. If it is a MK2, the engine bay rust might be a more serious problem.
Surface rust you can treat with an inhibitor, where you can’t get down to bare metal in your engine bay.
Never found Kurust to be any good. I now use Bilt Hamber Hydrate 80. It is much easier to use. But I’m sure there will be other oppinions.
Thanks. It’s a high mile Cat S from a rear collision so it’s worth very little in terms of resale. If I was to start sinking real money into an mx5, I’d buy a mk1 instead as I could probably just buy another mk2 in the same condition it is now for the same money it would cost to repair mine.
I’ll give it a go though and hopefully get a couple eyesores out of the way.
