Is there any point changing the steering fluid?
Car is presumably on the original fluid, so it is not young, but is this a service item or pretty much indestructible?
And a similar question, is there any benefit in changing clutch fluid?
Not looking to create work for myself, but am trying to do a top to bottom service as the car is new to me.
Do a dip test on the steering fluid. If clean red ATF, leave it be. If black then yes, see the various options explored before the successful resolution in this thread!
Clutch fluid shares the brake reservoir, and the clutch bleed should be done at the same time as the brake and every couple of years (depending on usage) because it is hygroscopic.
