I shall be attempting to log my mucking around in and around the car here.
Firstly, I fitted the intermittent wiper stalk. Dead simple, 5 screws total I think.
I bought mine from MX5parts, as I couldn’t find any from an rx8 on ebay.
I timed it beautifully for the run of rain this week, so I managed to test them out, much better than the stock speeds so I was made up!
I followed this video: https://www.youtube.com/watch?v=k5Q03aF0KCg&t=370s
Then the next task I set to was changing the gear selector limiter, again bought from mx5parts Gear Lever Selector Limiter Plate, MX5 Mk3/3.5/3.75 6spd & Mk4 – MX5 Parts
Disassembling the center console was unexpectedly easy with my iFixit toolkit, which I was pleasantly surprised by, as I was expecting to need additional trim tools.
All was quite straightforward to get off, especially following this thread Notchy gear change - selector limit plate wear on NC 6 Speed.
The only note I have is that the shift boot (Genuine Mazda MX5 Mk3 Upper Gear Shift Boot - MX5 Parts) the plastic ring and all slides over the top, I thought that the rubber needed to slide over the ring.
A mostly moot point as it was ripped on either side anyway, so I replaced it, but useful to know.
You can see the ring in this photo in the bottom right.
After those are out I pulled the the gear stick out and added some 75w90 gear oil to the cup at the bottom, which I believe is the correct place.
This done the parts were swapped, and replaced, and back in goes the trim. Don’t forget to plug your window switches back in, as I nearly did.
Driving it now, I can feel the difference in finding 1st and 2nd, unfortunately it hasn’t completely cured the gearchanges, cold shifts are… crunchy? notchy too.
With some luck Rodders will cure it with a diff and gearbox oil change at the end of the month.
In the meantime, I have to carefully shift into 2nd so as not to grind the gears.
