Changed the door speakers (daughter bought me some vibe ones for my birthday), it still had the original ones had to cut off plugs and solder wires cause didn’t have adapter wire you can get. I thought the old ones were ok until I fitted the new ones as I had them out I sound deadened around them. And lubricated window mechanism (they fly up & down now) wow what a Difference. She was right the old ones were rubbish.
Started replacing rear discs on my mk1 Eunos weekend before last and all went well on near side but the offside calliper was seized. Very frustrating as the weather was so good and I haven’t had the hard top off long - was itching for some top down driving. Ordered a refurbished calliper form MX5 Parts which I fitted over weekend just gone. I painted the visible parts of the disc with silver Hammerite to avoid the unsightly inevitable later rust, which is looking good- so far! Echoing recent comments on another thread - far easier to get help bleeding the brakes - my cheap one man vacuum bleed kit did not work well at all as vacuum weak and connections onto the bleed nipple not air tight. My son helped me by pressing the break pedal and the braking is fantastic now and brake fade has disappeared.
While the car was on axle stands and wheels off I replaced the front mud guards and did a mini service.
Next job is to replace the speedo dial with one that shows both kph and mph for my trip to Italy in Aug - would like to know if anyone has experienced difficulties calibrating the speedo after fitting a new dial - one You Tube video suggests calibrating while driving the car!!!
The issue with using copper ease etc on brake components is that over time the petroleum based grease attacks the rubber seals causing them to swell, then the pistons don’t retract properly so the brakes drag/bind. Pads and discs wear prematurely (or overheat if the binding is bad). Similarly if the grease comes into contact with any rubber boots/bellows they swell/distort and lose their seating, letting grit/salt/water etc in.
I’ve always used red rubber grease on the slide pins. Copper grease on the brake disc backing plates and pad locating points in the clips, use sparingly.
I’ve also wiped the caliper piston rubbers with red rubber grease after a clean up, again used sparingly.
And very nice it looks too! Have you had chance to drive it yet Mick? I loved the whole feel of it compared to the thinner, smoother OEM wheel. The red accents are a great look too, a job well done mate!
