I haven’t driven the car for 2 weeks.
The battery is new, type 053, that I fitted a month ago. I’m keeping an eye on the voltage,
to get an idea of the drain.
Showing 12.28V right now, so shall give it a top up this morning.
Originally Posted by: Paul H Go to Quoted Post
Changed the nearside door mirror on my RF, that was fun but good to see the inside of the door behind the cards, the door has been treated inside with a waxy substance which is quite reassuring for the rest of the car, had to change it as the garage door savaged the original the other night, all back together working as it should, then added the carbon covers to both door mirrors to match them as the replacement mirror was a lovely bright red and I have a grey RF !. now indoors trying to get warm.
MickAP: I wouldn’t be happy that the chassis is 100% protected without checking, just saying.
Mick when I bought the car had it on the ramps before delivery, had a real good inspection, clean as a whistle !, first thing I did (on dry roads) was to take it to be steam cleaned and completely treated (with Waxoyl type treatment actual name escapes me at moment)by a company up near Warwick, reason being intend to keep car for some years, SWMBO has said that is the last one you have for the forseeable future, unless we win the lottery that is.
Despite having only 24,000 miles on the clock, the service interval calls for diff and gearbox oil changes at 4 and 5 years respectively. Not knowing if these had been done (in my experience dealers are notoriously bad at sticking to time based servicing schedules), and with a track day three weeks away, I changed them today, using Ford fully synthetic 75W-90 BO in the gearbox and Mobile Mobilube1 fully synthetic SHC 75W-90 in the differential.
No chunks of metal out of either box or diff, so that’s a good start!
Whilst the car was up in the air I was going to bleed the brakes, but discovered to my shock that in my fairly large collection of tools I don’t own a 21mm socket for the wheel nuts. I could have used the tool kit brace, but that would have meant not being able to torque them back up correctly. 21mm impact socket ordered!
Went to rebuild the rear right brake with new discs and pads plus painted calliper. That went easily, probably 10 min in total. Then had a closer look at a repair made by a previous owner on the back of the sill. Ended up getting the power tools out to clean it up, tidy up the welds before coating the area with rust convertor. Tomorrow will be paint followed by waxoil. I have a feeling the other side has been repaired to so am expecting to repeat this messing task.
Had mine under sealed two weeks ago at MX5 City. They seem to know their stuff and were involved in the conversion of an NB (I think) auto to manual conversion for Practical Classics magazine. Took a day with fairly benign weather, I.e. it didn’t rain on the way there but hammered it down on the way back.
Could do with a roof down blast to blow out the residual smell, although Dinitrol smells a bit like creosote and we quite like it !
Pending a trackday early next month replaced the brake fluid with ATE Typ200 and checked the front brake pads. Rear pads changed at dealers before we bought the car, and the front pads had plenty of material left on them.
As my project goes ive Painted under bonnet,wings,headlight covers,both bumpers,rear panel, boot lid and door mirrors on my mk1 Eunos v special in the last week or 2. All off the car.
weather permitting hope to get the rest of motor done shortly.
I may be doing a disservice, but everything drained before and has done since I shoved the Karcher down the flue (albeit causing the wheel bearing noise).
What I was very disappointed with was that having phoned to agree a time they could look at it, they were busy and didn’t offer to put it back on the ramp to check from underneath and was quoted a couple of hours labour charge to remove all the trim and trombone brush it, which I’m not sure is the correct procedure for the PRHT.
still, at least it’s better protected than before. … hopefully.
Edit / ■■■■■■, meant to quote Meneer but picked up the wrong post.
