As the topic says, what does the weather need to be like for the top to go down?
I would say clear day with 12 degrees C or above.
If it’s not raining and the top is dry it goes down
Dry weather any time of the year normally.
We’ve been doing a good deal of walking just lately locally so not used enough. It’'s looking odds on for an MX-5 lockdown this winter.
Went to the chippy and back top down this evening at 7 degrees C, ND manual advises not lowering the roof when the temp is below 6 degrees.
Any time it’s not raining, sleeting or snowing.
PRHT: therefore dry and sunny - regardless of temperature.
Hats live in the elbow box, O/C cap to prevent sunburnt bald patch or woolly to prevent frostbite.
Prht also. Anything above -5 degrees. Seat heater on 4 and heater blower on knees.
That is not something I would have even thought to check!
And to answer the question, I am not sure I have a lower limit as long as it isn’t pouring (I would say raining but I have a habit of getting caught out by it).
Had the roof down this morning in ~9deg and again this evening (even though it was dark, I had a new exhaust so wanted to hear it) when it was slightly cooler
Although its our " weekend " car, its used all year round, and if its a dry day then its top down, and if its chilly , then its hats and heater on, but if its raining or absolutely freezing then we go toastie with lid up
I rode my motorbike all year round also, except under extreme conditions
Anything above 28MPH, below this seems to be when gravity over comes air flow and you get wet.
Ian, I like that steering wheel. Where is that from?
It’s a Raid airbag wheel, bought it about 12 yrs ago to replace the usual airbag wheel on the 2.5 Sport.
Great, thanks.
This is probably because the roof material can be quite stiff at low temperatures.
Solution: Run the heater on high with the roof up for a few minutes to soften the hood material and then lower it!
Ian, what exhaust did you go for? Im currently looking at options.
I went for a Cobalt one
Was this on the ND? If so, is it deeper than stock or just a better overall sound?
TIA
It was indeed, deeper and louder
That will just leave you with a frozen roof to put back up when you have finished your journey.
