Hello everyone, I hope you are well.
Sorry for the radio silence, iāve been working 70 hour weeks and my health hasnāt been greatā¦thereās probably some correlation there!
Anyway, quite a lot of progress has been made, so here goes.
Ground problems.
Iāve had ground problems for the entire length of this project so I set about changing everything.
I started from the battery and worked my way forwards. I stripped back the wiring at the battery and the PPF, not ideal - the PPF actually looked like it has burnt somewhat but it might be an illusion.
I took a wire brush to the grounding points and changed the connectors.
Unfortunately, this didnāt actually make any difference. But, it was good to know that the grounds were in tip top condition.
Starter Issues
As youāll remember I was getting clicking but no cranking. I ordered a UV Joint socket extension to that I could fully detach the starter and gave it a wobble, then refitted it. It made a different noise! I went back and left it slightly loose, and result - it did what a starter should do!
Crank problems
This is a weird one and technically still ongoing. Once the starter started working, I assume iād be home and dry (idiot) - as the car had always atrted before once it had cranked. Alas, no:
The weird thing about this is, the battery was 100% full (and a new higher cranking battery too), the ground issues clearly werenāt there. It took about ten attempts of the cranking above to even get a splutter, so it could mean some kind of newly developed fuel pressure issue somewhere.
Alternator squealing
After I eventually got it started, it made a hell of a noise so had to set about adjusting my alternator position, which is always fun! The kit comes with an adjustment bar, so once youve got the bolts in the correct position, the adjustment is actually pretty straightforward.
Interior
The interior is coming together now, after many reincarnations. I settled on the tillett B5, which is now fitted in the car along with new carpets. Iāve also had a go at some āretrimmingā myself and covered the door tops in alcantara. Iāve got a Momo gearstick to match my steering wheel, changed the tombstone for the extended JASS version and changed the air ā ā ā ā ā as mine were a bit crusty. Anyway, possibly not to everyones taste but I like how itās looking at last!
Exterior
Iāve changed the headlights for some crystal units and the sidelights for some sequential items from ILM. Iām not sure wherther iāll keep them or not, but iām leaning towards keep!
Hope youāre all keeping well!
Andrew
