- My model of MX-5 is: __NC Mk 3.5
- I’m based near: __Haslemere
- I’m looking for technical help or recommendations on: __electrical issue stopping the car starting
Hi
I was driving home in the rain a couple of weeks ago and all my heating/aircon started working intermittently then stopped completely with no lights on the controls. Everything else on the car was fine - lights, engine, dash, wipers etc.
I read the DTC with Forscan and found the code:
===IC DTC U0028-60===
Code: U0028 - Vehicle Communication Bus A
Status (-60):
At this point the car started fine, so I just thought the heating control module had failed and bought another one from a breakers. When that arrived I tried starting the car again before fitting the new one and despite all the lights on the dash including the immobiliser working as normal it didn’t crank. Suspecting the heating module was stopping things working I removed it and the radio and the car started OK. By then it was getting a bit late and starting to rain so I gave up.
Next day, the car wouldn’t crank at all, either with or without the replacement or original heater module plugged in.
Since then I’ve tried multiple times but haven’t been able to get it to crank. I’ve removed the glovebox and checked in that area for water damage but it all seems fine - it was leaking, but I fixed that last summer.
Does anyone have any idea what could be wrong and where to look next?
Matt
