I’m looking for technical help or recommendations on: __Reversing Sensors
Hi, as part of sorting my rear bumper I have acquired 2nd hand bumper with fitted revrsing sensors, loom & ecu. Could anyone give me a bit of guidance on fiting wiring etc for reversing sensors please? Thanks … John.
Have received bumper … I have 4 wires coming from ecu … I assume the black wire which has a ring on end is to ground, the red wire to live on reversing light, but where would the 2 blue wires go?
Thanks for your help…
That picture is complete and only missing the transducers, the four bits that live in the bumper. Those blobs on the ends of the leads plug into the transducers.
The blue wire is a test/calibration loop.
. Park the car with rear bumper 50cm from a wall.
. Check the blue wire loop is connected to itself, switch on the ignition but not the engine, select reverse and wait for between 10 and 100 seconds while it self calibrates “BEEEEEEE…P”.
. Switch off.
. Open the loop again and tape the ends to protect them from shorting to anything.
I soldered my + and - onto the tangs at the back of the reverse-light socket, no wires needed cutting etc.
Does it matter which way round you hook up to the reversing light? Also, seeing as sensors were on an MX5, do I need to calibrate (most probably will anyway…)?
The light bulb itself, no, but wires from it to the reversing sensor control box must be correct polarity + → + and - → -, unless you want it to take up smoking.
All fitted and working well. I used a rear earthing point for ground wire & used the red/yellow wire of reverse light connection to tap in to for red power wire. Pretty much same routing & location of control box as you did…
Only one embarrassing moment! When I checked that sensors were working they were beeping, so I thought something was wrong …
Haha … forgot about the stool I was using! Yes the sensors were definitely working!!! Went for quick drive then reversed back onto driveway and they worked well.
When ever I select reverse I get a short beep. I think they are set a bit sensitive. I haven’t calibrated control box yet … I taped up the 2 blue wires to light loom on LHS, so quite easy to get to for calibration when I get round to doing it…
Thanks heaps for your valuable input!
