- My model of MX-5 is: 2.0 NC Mk3 MX5 (manual 5 speed, PRHT)
- I’m based near: Calne, Wiltshire, UK
- I’m looking for technical help or recommendations on: Intermittent PRHT fault. Worked when I bought it, doesnt really work now. See below for details.
The problem:
On a flat surface, in neutral with engine running or with ignition on, PRHT does not retract reliably. I can undo the latch and the roof warning light to the left of the hazard light illuminates. Here is where it gets really odd; sometimes it is silent, sometimes an intermittent beep, sometimes it goes halfway and sometimes the buttons dot THE OPPOSITE to the action displayed on them!
I have managed to open and close the roof fully once today through button mashing, turning off, turning on, patting the roof firmly etc.
What have I done so far?:
I have read a lot of forum posts about broken limit switches, broken motors, poor engagement of gear teeth etc. There is no noise at all when the roof decides to work, no graunching, grinding or clicking… The limit switches seem fine, the warning buzzer clearly works, there is no water in the cabin or the ‘tray’ behind the seats where the roof tucks away. Also there is no physical impediment to its movement (cuddly toy, A-Z etc). The hinges look really well greased and when it chooses to move, it is smooth as silk.
I have disconnected battery for 30 mins. Clock cleared but radio didn’t ask for code, did I leave it long enough?
Battery voltage is 12.58v cold and once running it is charging beauifully (hopefully ruling out under and over voltage issues).
What do I think is wrong?:
I am stumped, that’s why I am here. Anyone seen the mixed button, intermittent PRHT roof problem before? Thanks in advance.
PS back into MX5 after a long hiatus. Sold a BMW 645 to buy this as I wanted to be more connected to the fun driving I do. It is definitely fun but currently isnt living up to the Which? survey suggesting it is the most reliable used car you can buy in the UK. I am not sulking or particularly cross, it is a relatively cheap used car, the weather isn’t scorching hot, the AC works, it drives beautifully, it is clean and well looked after, it is just the roof that is ‘showing off’.
